one high priority.....
i don't understand why there are one a few defined line weights on the layers....
architecture offices like to use there own image and design,
in my country one of more used line tickness is 0.03 or 0.05, and the smaller defined is .013
why this limitation to the software?
una cosa prioritaria.....
no entiendo porqué hay definidos grosores de línea en las capas....
en mi país las oficinas de arquitectura acostumbran a tener su propia imagen y diseño, uno de los grosores más usados son las líneas de 0,03 o 0,05, y el más pequeño definido es 013
¿porqué esta limitación dell software?
Traducido medio bien por el moderador
Customized line tickness
- ricardomoura
- Tímido
I believe that you commit an error of measures. 0,03 are an absolutely imperceptible dimension, if you think in the references of the Rotrings, where the 0.13 were the smaller size.
Sure, your references are in inches, our references in centimeters, I think.
Creo que cometes un error de medidas, 0,03 es una dimensión absolutamente imperceptible, si piensas en los Rotrings como referencia, donde el 0,13 es el tamaño menor.
Seguramente, tus referencias son en pulgadas, nuestras referencias en centímetos, creo yo
- ricardomoura
- Tímido
no i'm pretty sure i'm working in cm....
a plotter isn't a rottring, you can have a diferent design, ....
we use smaller values, then 0.13
you can try on autocad or vectorworks, and u will have total liberty to customize ur pens....
but honestly i dn't understand why the fixed lines tickness? why not let the used define is design?
there is so much liberty in other aspects of the drawing, why not here......
Vamos a fazer mais confusao e reponder em português ao amigo,
Ricardo, por aqui nós falamos espanhol, nao dá pra voce tentar em espanhol? Nao sei se todo mundo fala ingles...
Vamos lá. Voce pode perfeitamente definir estes espesores de pluma a 0.01 se voce quiser. Extras > Definicion de Elementos > Def. y asign de Plumas, e ai você configura isso.
Vamos a hacer más confusión y responder al amigo en portugues...
Puedes perfectamente cambiar estos grosores de pluma por defecto en Extras > Definición de elementos > Def. y asign de Plumas
- ricardomoura
- Tímido
- ricardomoura
- Tímido
- ricardomoura
- Tímido
Perdí la mitad que el pelo que hace esto. ............
Yo le mando un mensaje a apuntar olvidarselo apenas. ...
mil gracias
desculpas pelas tradução manhosa mas vem de um site de traduções
mil gracias
¿Por qué cuando no sabemos hacer algo siempre decimos que porqué el software tiene tal o cual limitación? ¿No sería más fácil decir, como puedo hacer esto, en lugar de dudar que el soft lo haga o lo deje de hacer?
En fin, como diría Blacky, mariconadas de arquitectos...
Why when we do not know how do something we say why this limitation to the software? It would not be easier to say, how I can do this, instead of doubting that the soft does or not?
In short, as Blacky would say, "mariconadas" of architects...
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 25 invitados
